Drift performance iridium series gauges
Over Boost - Motorsports
Beyond 20,000 RPM!
Bandar Sunway
http://www.overboost-motorsports.com/iridium.jpg
DRIFT PERFORMANCE IRIDIUM SERIES GAUGES
- Available in both Iridium Red and Iridium Blue
- 5 inch tachometer diameter, 3 3/8 inch for speedometer and tachometer and rest are 52 MM diameter in size
- Digital LCD display with highly responsive and accurate microchip
- Attractive opening ceremony with twice full sweep and system check
- Tachometer series both 5 inch and 3 3/8 inch are with dual stage programmable shift light
- Dual stage shift light are pre shift and shift point settings, your able to program the per-shift and shift point where pre-shift point would be yellow LED warning light and shift point is high luminous powered red color LED
- Electronics Gauges for maximum efficiency and accuracy
- Complete with sensors, wiring harness, sockets, mounting and necessary parts
- 1 year warranty on manufacturing defects
- Made in Australia
VIDEO
YouTube - DRiFT Mätare i Sverige endast hos Hova.com
YouTube - Unige design digital gauges on supra
YouTube - Drift Iridium Series Digital Gauges from DRIFT Performance Products ID5681
PRICE
IRIDIUM BLUE SERIES
DP-1001 - Air Fuel Ratio Gauge - RM 349.90
DP-1002 - Fuel Level Gauge - RM 349.90
DP-1003 - Oil Pressure Gauge - RM 379.90
DP-1004 - Oil Temperature Gauge - RM 349.90
DP-1008 - Turbo Boost Gauge - RM 459.90
DP-1009 - Vacuum Gauge - RM 459.90
DP-1010 - Volt Meter Gauge - RM 349.90
DP-1011 - Water Temperature Gauge - RM 349.90
DP-1005 - Speedometer Gauge - RM 549.90
DP-1006 - Tachometer Gauge - RM 549.90
DP-1007 - Tachometer Gauge With Shift Light - RM 619.90
IRIDIUM RED SERIES
DP-1012 - Air Fuel Ratio Gauge - RM 349.90
DP-1013 - Fuel Level Gauge - RM 349.90
DP-1014 - Oil Pressure Gauge - RM 379.90
DP-1015 - Oil Temperature Gauge - RM 349.90
DP-1019 - Turbo Boost Gauge - RM 459.90
DP-1020 - Vacuum Gauge - RM 459.90
DP-1021 - Volt Meter Gauge - RM 349.90
DP-1022 - Water Temperature Gauge - RM 349.90
DP-1016 - Speedometer Gauge - RM 549.90
DP-1017 - Tachometer Gauge - RM 549.90
DP-1018 - Tachometer Gauge With Shift Light - RM 619.90
Over Boost - Motorsports are the one and only Authorized Distributor and Authorized Import Agent for Drift Performance Products
http://www.overboost-motorsports.com/zthlogo.gif
CONTACT DETAILS
Address - No 28A, First Floor, Jalan PJS 11/7, Bandar Sunway, 46150, Petaling Jaya, Selangor, Malaysia (same row as N1 Racing, beside WRC Lighting)
E-Mail - [COLOR="Black"][email protected][/COLOR]
Tel - +603-5611 6628
Mobile - +6012-955 1800
Blackberry Pin - 2284DEF5
Website - OVER BOOST - MOTORSPORTS
MSN - [COLOR="black"][email protected][/COLOR]
Skype ID - overboost-motorsports
Facebook - Over Boost - Motorsports | Facebook
Mudah - PRO Niaga: Over Boost - Motorsports
CLICK HERE FOR CONTACT FORM
