Good new for all racer boy. I have solution for those guys who experiencing of frequent mounting failure due to increased horsepower. I have 10 sets DIY engine mounting kit for sale. These kits are made from high quality urethane. Each set comes with preset ingredient and all you need to do is just mix and pour the urethane into your original mountings. Once harden in 2 days time, they will transform into a mounting like nismo is selling right now. This would not only make your mounting more solids but also increase of horsepower due to lesser engine movement. Each set is more than enough for 4 mountings in your car. They are imported from USA.
Don’t worry, they are not nylon or teflon that the engineering shop is selling right now. This is urethane formula, which allows some small amount of flex to avoid your car from cracking. There are 2 types of hardness. The soft one, which is suitable for daily driver, cost RM300.00 and the hard one, which is a even tradeoff between performance and comfort cost only RM280.00.
Interested, do call 012 3649649 (Fei) for inquiry.
Following attachments are the finished engine mounting from U13 turbo ready to be use.
