To get codes out of this type of connector, jump the "TE1" and "E1" teminals. Finding these terminals is easy as the inside cover of the diagnostic connector contains a schematic of the connector pinouts. If the underhood emission decal (VECI) is still intact on your vehicle, the proper pins for this are outlined there as well.
The trouble codes will appear as flashes of the check engine lamp. Be sure the ignition key is on, the engine off, and your foot off of the accelerator when reading the codes. Two different codes may appear: One-digit and two digit. One digit codes have an approximate 4.5 second delay between flashes with the check engine light illuminating for about a half of a second. Mulitiple codes have a 2.5 second delay between them. For example a code two flashes the check engine lamp two times in a little over one second: I I. If two codes are stored, such as a code two and a code four, the lamp may flash as such: ....I I....I I I I. Crude examples but you get the idea. Two digit codes are similar but will flash the lamp with the first number first and the second number last. An example of a code twleve is I ....II and a code twenty four is I I..IIII.
