Good evening all sifus, I was actually trying to save some bucks n try to install the shortshifters in to my stock shifter.
After having the trouble from removing the armrest box from the hand-brake n the compartment box. then trying to remove gear compartment that is lock tight under the (EJ ori gear lock), had a struggle almost broke the lock metal panel. Finally removed it.
Then found a gear rubber stopper surrounding the gear stick, but cud not do anthing from there...
Anyone can help???
Anyone can help???
