Convert auto to manual 20v engine
BooN
PeraK
Hi... I wan to convert my blacktop 20v from auto to manual. Wat are the cost?? Need advise...
You need:
- Clutch Master Cylinder & Hose - RM100 (Used)
- C52 or C56 5M/T Gearbox NON LSD - RM600 (Used)
- Shifter Assembly + Cables - RM100 (Used)
- Clutch Pedal & Manual Brake Pedal - RM100 (Used)
- Manual GB Engine Mounting - RM170 (New)
- 20V Flywheel - RM250 (Used)
- 4A Clutch Plate + Pressure Plate - RM350 (New OEM Toyota)
- Installation - RM200 (Max 2 Working Days)
- Gearbox Oil + Clutch Fluid - RM60 (New)
Total: RM1930
* All prices are estimation nearest to the actual amount charge.
Just call TRIAL Tuning Spirit at 03-7981 9992 - Ask for William San
I've got (near) full set for sale.
The things which I have: -
1) C52 gearbox
2) Shifter Assembly + Cables
3) Clutch Pedal & Manual Brake Pedal
4) Manual GB Engine Mounting
5) 20V Flywheel
6) 4A Clutch Plate + Pressure Plate
I don't have: -
1) Clutch Master Cylinder & Hose
PM me if you want it.
I also have a short shifter if you are willing to top up.
I also have a C56 gearbox, but it's in my sister's car now. We are willing to sell it if you can make good offer.
How will the engine perform with manual transmission?? I wan to know more before doing this thing.. Thanks for all ur advise~~~
i tot 4AGE auto tranny ECU and Manual tranny ECU is different?
yealo is it the ecu need 2 be change also?? reli need toyota sifu to teach ler...
Hmm... is the wiring diffrent as well? Can he just plug in the manual ECU?
John
In ur opinion la... got any diff between 5 gear with 6 gear?? or jes the same function??
hwhahaha.... me still new mah dono much bout this engine also. Jes know this engine from cartoon movie nia. But is it this engine so power??? Mind to share a little bit bout this engine?? :lol:
If 2 car side by side, with all similar spec but one with 5sp GB and the other one with 6sp, the 5 speeder will cry after 3rd gear. And will go sourcing for 6 sp GB right after the race :lol:
BTW, friend of mine is letting go following stuffs:
1) C56 GB (done 40kkm only)
2) BLT Head (without ITB)
3) Levin AE111 N1 piping
PM me if you need anything above. Location is Puchong.
aiyo, levin818, like that c52 cry til no tears loh...
i'm using c52 on bt now... really sad...
a suggestion...
find someone who wanted to change manual to auto... exchange the items. cut down cost....
ehehehe...
Tats y i wan to know wats the diff loh... Wanna make a wiser decision cause dowan to regret after convert 2 manual. Anyone who wan advise me are free to gip their opinion..... Thanks Thankss...
** Paging for silvertop @ Roland **
You comments pleasssse :lol:
arnet,
So if u want the C56 from my friend and make the C52 owner cry, feel free to PM me :lol:
Wat modification can we make for 20v engine dude??? Well as i know from people around say can rev until 11,000rpm..... :blink:
