Chopper Bike - Beach Cruiser
All Other Stuff
rogz
Brand New Chopper Bike.
Cool Bike to own. Something different From the usual Mountain Bikes, BMX & Racing Bikes ... This is what i call CHILLEX BIKE ... U CHill & Relax when u ride it ....
Normal Price is RM 1,100
SPecial Promo Price of RM 800
Call or SMS - 012 3727968
Location PJ
BMX racing was a phenomenon by the mid-1970s. Children were racing standard roadbikes off-road, around purpose-built tracks in California; give some ideas on kawasaki er-6f is a powerful sports motorcycle from the house of Kawasaki. It looks quite similar to legendry Ninja Series bikes. Many of its parts like front cowling are quite identical to Ninja. The design of ER-6f is MotoGP-inspired. It is available in ABS version also. ABS adds extra 4 kg to its base model weight.
It features 8-valve, Liquid-cooled 649cc Parallel Twin Liquid-cooled, DOHC that generates the impressive power of 71.07 HP @ 8500 RPM and torque of 66 Nm @ 7000 RPM. Kawasaki ER-6f features an advanced Digital fuel injection system with two 38mm Keihin throttle bodies that delivers fuel flawlessly and ensures smooth, overall performance.
It has high-tensile steel diamond frame that is amazingly strong and provide stability to bike on high speeds. Dual 300 mm front and 220 mm rear petal disc brakes offer fabulous braking power. Besides this you can go for ABS model that that incredible stopping power. It has digital instrumentation panel that includes clock, odometer, speedometer, trip meters and a digital tachometer. It shows the information in a LCD screen. An LED tail lamp adds charm to its looks.
It offers a great ride experience due to its performance and comfort features. Many riders prefer joe rocket brand for selection of their gear. It has rubber coated footpegs to reduce vibration. Windscreen screen helps to protect rider by deflecting the air.
Facts:
Engine and transmission:
Displacement: 649cc
Engine type: Twin, four-stroke, Liquid-cooled, DOHC
Power: 71.07 HP @ 8500 RPM
Torque: 66 Nm @ 7000 RPM
Compression ratio: 11.3:1
Bore x stroke: 83.0 x 60.0 mm
Valves per cylinder: 4
Fuel system: Digital fuel injection with two 38mm Keihin throttle bodies
Ignition: Digital CDI
Gearbox: 6-speed
Final drive: Chain
Clutch: Wet multi-disc, manual
Dimensions:
Height: 1,200 mm
Length: 2,100 mm
Width: 760 mm
Seat height: 790 mm
Wheelbase: 1,405 mm
Brakes and wheels:
Frame type: Diamond, steel
Front suspension: hydraulic telescopic fork 41mm
Rear suspension: Offset laydown single-shock with adjustable preload
Tires:
Front: 120/70-ZR17
Rear: 160/60-ZR17
Brakes:
Front: Double disc
Rear: Single disc
Front brakes diameter: 300 mm
Rear brakes diameter: 220 mm
Physical capacities:
Gross weight: 204 kg
Fuel capacity: 15.51 L
Color options: Metallic Flat Spark Black
