Ceramic Coating
Car Shops and Services
Ceramic Coating
paranoid_android
Ceramic Coating
* Stand until 2000F (so good for exhaust manifold and turbine housing)
* Reduce under hood temperature
* Exotic look
* Prevent corrosion and increase part life
* Available color: Satin Black
Price depend on size of manifolds and turbine housing so please call or sms us for price quotation.
Coated by Dynatech
No.22A, Jalan TP 7/2 UEP Light Industrial Park
40400, Shah Alam, Selangor, Malaysia
Shidie (013248859)
Ariff (0126212352)
Blog: Coated by Dynatech
Ceramic coating is basically a thermal barrier designed to reduce radiated heat and prevent corrosion of the part. Since the ceramic keeps the heat inside the part, such as an exhaust header, it increases the exhaust velocity resulting in a more horsepower.
Most people see a 1% to 5% horsepower increase, depending on the configuration. The most common applications for ceramic are exhaust headers, downpipes and turbocharger turbine housings. The life of the part is also increased 3 to 5 times due to the corrosion resistance of the ceramic coating, as long as the part is kept below the prescribed heat limit.
How much would a standard manifold cost? Rough estimate?
PM me too...standard mivec manifold...how much and how long would it take?...
Hi Bro, thanks for your reply. Once you get a bigger oven let me know the cost to do the manifold!
I have sent PM but if u dont get it, let me know :driver:
---------- Post added at 11:36 AM ---------- 6 hour anti-bump limit - Previous post was at 11:35 AM ----------
Its not our oven, its our sandblast cabinet, sure bro, once we upgrade, will let u know :driver:
---------- Post added at 11:41 AM ---------- 6 hour anti-bump limit - Previous post was at 11:36 AM ----------
Recent Works!
Bro, now we can do NA extractor/header, check your PM :driver:
---------- Post added at 11:17 PM ---------- 6 hour anti-bump limit - Previous post was at 10:53 PM ----------
Ceramic coated 4g63 exhaust manifold in action, Coated by Dynatech for APC (Advance Performance Centre, Subang Perdana)
