Car Battery Terminal MADE from copper
Summer_foo
Pulau Pinang
*High Performance Copper Battery Terminals Add Style to Your Install While Optimizing Current Transfer
FEATURE:
-Specifically designed to ensure greater DC current transfer between car battery and cable.
-Wire contact solid copper construction for maximum corrosion resistance and power transfer.
-Tapered design covers the unattractive lead post for maximum aesthetic appeal.
-Special battery terminals extend connections for easy power cable installation.
DESCRIPTION:
When it comes to your mobile entertainment system, style and performance go hand in hand. With a tapered design wire contacts, and solid copper construction, Copper Battery Terminals cover your battery's unattractive lead posts to deliver improved current transfer for an install that looks as good as it sounds.
Package includes:
1pair of Copper Car Battery Terminal
8 x M8 set screw
4 x M5 set screw
2 x M8 cap screw 20mm(S steel)with washer and nut
Price: RM180 WITH POS
Warranty: NIL
Dealing method: Booking, Bank In then POS.
Location of seller: Penang-BM
Contact method/details: 0124988955
Age of item: NEW
this product need pre-order...
once product ready then only made the payment.
http://uf.cari.com.my/forumx/cforum/forum/201210/08/213610ecyjczex2jjrqinl.jpg.thumb.jpg
penang-BM..
---------- Post added at 08:35 PM ---------- 6 hour anti-bump limit - Previous post was at 08:23 PM ----------
i from penang-BM..
this item need pre order...
I NEED ONE SET OF IT, BRO..WITH POST TOTAL RM ? KUALA LUMPUR..Tq
note.
May i know ur battery size? regular or small size?
I will msg you when product ready
thank for support..
---------- Post added at 03:12 PM ---------- 6 hour anti-bump limit - Previous post was at 03:09 PM ----------
note.
thank for support..
Hi bro, is this thing prone to oxidisation?
Copper is prone to oxidation, but not really effect the performance...
Before install polish contact surface, most important area is battery and terminal contact area.
Continues is hole and awg contact area.
