can modify like tis mar?
I3en_I3en
YOKOHAMA
sifu...
can modify the ignition system like tis mar???
http://img83.echo.cx/img83/3576/untitled4gx.gif
Is the I alternator or battery? not so pratical, add weight to car only.
i think cannot coz in the distrubutor the contact doesnt touch each other. only high voltage can jump the gap.
Wat u r trying to show is actually using 4 ignition coil n each for every plug.. i dun think this will give much improvement as the coil will also come out same spark for plugs, waste money only.. a good upgrade will be to make the coil to give two spark on each contact of the contact breaker.
I m now DIYing a electronic ignition for my car. Will be doin another electronics ignition circuit tat can make multispark for the spark plug at high speed rev. This will give a good combustion.
how to do???
I3en_I3en said:
how to do???
Yeap... multispark... there are device selling tat can produce multispark. I got the circuit also.. i will try to post it out as soon as i found it. But i din try on it yet. It a device tat is connected to low tension ignition tat get signal of contact breaker. Then by sensing the speed it will control the output to ignition coil to give spark. At low speed the ignition is same but a high speed it will make the ignition coil to produce the spark twice to give a more complete combustion.
Here i attached is the link for the multispark ignition:-
http://www.electronics-lab.com/projects/automotive/010/index.html
4 booster
i dun think it will improve any. because there is only one firing at any one time. even u have 4 booster, the car ignation sys cannot firing all 4 ignitors in one time. twin spark like alfa will assist in proper combustion.
change coil will increse performance???
can simply change coil???
where to buy high voltage coil???cost how much???
home have a Lucas Gold coin...dunno can use anot???just plug and play no need setting right???
1- power to spark plug high but might be slow in frecuency
2- same amount of fuel and air >> same power produce even high spark
3- might be useful for turbo system
ignation
if the engine is std. i dont think just change the ignation sys will help much, a little i would say . even the differance is not noticeable , and it is not balance with what u have paid.
for a large improvement, we still have to stick to big cc, v-tec, vvti, turbo, high cam and ect.
just my opinion,plse correct me if i'm wrong.
