Hi all I have just purchased a airtrek turbo, I have a issue with it and am hoping you can help.
from what I understand they make 11psi as standard and that's roughly what the car is producing,after I put a gauge on it today but sometimes it feels very slow and does not boost correctly.
This happens 50% of the time, I checked the resistance on the actuator today and it was very weak could this cause such a problem or would it be low boost all the time if the actuator was faulty.
Also finally what is the safe amount of boost you can run on the standard turbo with a boost controller and no other mods? I read you can run 1 bar(14 psi) maybe a little more is this correct?
Thanks for any help
Thanks for any help
