BlackTop 6 speed
8313
btw all toyotarian sifuuus here....i wanna ask few question regarding to this 4AGE Black Top 20V 6 speed....
1.I get 2 noe dat there is sum engine tuned by Yamaha sum tune by Toyota is dat true? which 1 better?
2.Wat is da advantages of havin LSD couple wif 6 speed?
3.Can it loaded into ae111 1.3 chassis without any mod on bracket/ mounting?
4.Can i know wats da market or current price 4 a 4AGE Black Top 20V 6 speed wif LSD halfcut ?
5.Is there any good/ best recommendation 2 buy halfcut n also 2 convert location at klang valley
Hope dat all toyota sifuuus will help newbies lik me on dis doubt..............MOVING FORWARD >>>>>>>>>>>>>
1. Yamaha only produce 3S eng i think and also some motorbike
2. many diff...but 95% 6sp doesn't hav lsd
3. only timing belt mounting hav to drill hole
4. no lsd 5k+, lsd dunno
5. kajang, kepong, sg besi, n many more
i prefre the old motto......."Get the feeling" when u lost....hahahah
4A oso produce by yamaha .. as well as lot of other "toyota" engines .. cannot remember liau but i know 4A and 3S for sure laa ..
as for tuning .. the ECU is branded as toyota without 3rd party labels .. so not completely sure about who actually did the tuning but probably toyota laa ..
thx bro 4 all ur responses.......
btw still sourcing 4 more info on it...
all toyotarian >>>>>>>>
the 6 speed utilises the powerband of the stock 4A much better than the 5 speed ... although it can be expensive ... but IMO for driving pleasure and fun .. worth it laa
Certain 1970s' RG series toyota heads also developed by yamaha. In fact i remember i read that almost all heads under 2.5cc are developed by yamaha. I believe its some form of outsourcing or tech exchange.
juz wan 2 share dis info....... (blktop wif lsd-5speed)
my car become heavier when using lsd gearbox compared 2 previously (stock wif no modification)- if u go 4 drag race la, track race no xperience at all.....hehehe :-)
tested b4 wif my fren (small v in ef9 chasis), won every game, but after put lsd we're even....sometime lost..huhuhu :-(.... my pomen told me the lsd goes well wif modified engn or upgraded engn (lightened flywheel, competition clutch plate, extractor n racing cams).......if vicious lsd ok (wif stock engn)....
my fren owned a 6speeds BT, and i tried b4, the feel very good, good respone in track... u may try also, sure no regret:_:
Bro im using the BT 5 Speeds LSD gearbox, but i dun have the problem like u said wo. most of the BT gearbox got LSD 1... but normal LSD la:_:
mine don hav laa... just installed it.... mayb my skill isn't good enuff, hahaha.... my previous 4agze engn did come wif lsd, change 2 blktop unluckily it didn't come wif lsd, need 2 top-up more money 2 get d lsd.....
haha so unlucky for u.... coz most BT half cut i bought also got LSD 1:_: i just changed my gearbox last month, the gearbox i bought also came with LSD.... so u using a 1 way or 2 way LSD?
sorry...can ask 1 q?
if 5sp bt gearbox put no-lsd gearbox oil..is there any effect?
if 5sp bt gearbox put lsd gearbox oil..any effect also?
Kayy
1st the non LSD gearbox oil u mean, is call LSX gear oil. the different between the LSX and the normal gear oil is.... the LSX gear oil more thick then normal 1... the gearbox witch got LSD 1 must use LSX gear oil, reason is to protect the LSD....
ic..thanks...
1 more thing...normal ae111 bt 5sp...got lsd or not...how to know?
thinking of using lsd gear oil
kayy said:
ic..thanks...
welcome,
hmmm..... OK, there is a way to differentiate 1.5 Way and 2 Way LSD by looking at the Drive Shaft Mount hole.
A 2 Way LSD (Clutch Type KAAZ) will have a hole the size of a Cigarette while a 1.5 Way LSD, well u can put your finger into it (bigger hole laaaa)
The hole I am talking about is something like u can see through all the way to the other side
somemore if u r using a non LSD gearbox then no need to use the LSX gear oil la, coz the LSX gear oil expensive then normal gear oil, and it will make ur car feel more heavy....
wow bro 7Heaven u seem 2 know well bout dis 6 speed huh.......good explanation anyway.......helping me n others toyotarians.....hahahaha
team work.....
if you got extra money can use lsd gear oil in normal gearbox also .. no harm .. hahaha
thanx oso 2 u bro 7heaven......thinking of meeting u laa anywhere around s.alam or subang, but ur place seem so far... hoping dat one day can seat wif u at mamak stall n hav a longggggggg talk bout lsd (while eating roti tmpl n teh tarik), new in dis field n hope can get more knoeledge by involving in dis toyota forum........ :-)
