B8 need help
lynx_210
Hi to all sifu....
i hv a B8 but now got bit problem here hope all sifu can gv me a idea here thank you very much.......
when my car rav till 5k rpm (sometime start fr 4k+) it always not smoth n some times sounds like "PopPopPop ...." can any1 help me out ???
tried out used to control the fuel but still the same - or + fuel also same ...... change the plug n cable also the same.....
hello there.. might be ur air flow meter... try changing it or service it and see.. maybe can work...
yada nada...yoda...yoga
*edit* haiz.....
ehehhehe
POP POP POP...
NiJ put banana inside the exhaust eh...
fuel cut ar?
not yet tune nicely is it?
Thx to all sifu......
I can't tune my car coz of this problem n if is fuel filter when normal driving also got problem rite???? but now normal driving ok just only when full rav till 4-5k rpm then problems start..... its sounds like fuel cut but don't think so coz already open it...... ignition timing is all set to normal so will it b the problems still????
stuck fuel filter is like that 1...
can flow enough fuel for low rpm, but when reach high rpm will sputter
180 & 210 must use AFM. only mazdaspeed version will only use map sensor.
friend,
dun forget you are using different cam and maybe is also cause by your coil..
kk i will be in kl on friday.. on the 30/11/2006 meet up ok near serdang
tkk said:
friend,
yah i agree with kk, maybe caused by your coil....
Hehe
hye....
Check minyak mane tau ade tersumbat....
fuel pump pon check gak....
sumbat safc je mcm kawan... syok ooo...
can tapau gsr..........................
JarsOfClay,
wat point to tapau vtec...
i've own vtec n b8 too...
itu mitsu saja tatak pakai...
itu pasat tapau itu gsr turbo manyak syiiokkkkk!!!
die enjin baru maaa... 210 is from zaman hang tuah!!!
wakaka
no problem...
just give me a call. i will only come back on the 30/11 morning. and go off again on 1/Dec.
safc? y he need safc???? he keta kuat mar.... damien now wanna beat 3s-gte only!!!!! hahaha!!! eh... damien when ur car ready try wif my fren the levin 3s la... he did alot of stuff ady... i wanna see how 1.8 against 2.0 both oso monsters....
muz,
your friend 2.0 is dam monster? i'm very interested to see man. lets gather a TT ok !!!
