b18c block
lan evo
lets say i have a b18c block.the block is blown,crank shaft bengkok,bearing wore,piston crack.
i want to rebuild it,what i need?how much?
pls help.thanks
pls help.thanks
If yr b81c crank shaft bengkok & blown block, the only solution is change
engine kosong...
no need to rebuilt....waste yr time/money...then reliability issue will be arrised later on...headache again...
At present, very2 hard to find 2nd hand b18c crank shaft only....
if b16a crank shaft sure easy to find...
or another solution is down grade to b16a engine...or get b18cR engine kosong heh2 :regular_smile:
hattech-v said:
i know where to get b18cr block... hehe.. but oversize edi...
haha mie...oversize to what bore? with complete crank/rod/piston?
if yes better u keep it for spare heh2...
or u can upgrade yr 1.6 with 1.8 inside heh2...
no more upgrade la g... now damn broke....
the b18cr block is complete block with oversize piston. its 83...
ooopsss poji..... this kind of quote implicates dunia akhir zaman ekekekekeke
if talk about fuel consumption issue, better sell la yr 4.7 FD...
together with lsd cheap2....
after this u've a reason if 'jiwa kacau'....
not using it edi...
