Im planning to change to skunk2 pro intake manifold and rebore TB size. Whats the max rebore size for b16a throttle body?
70mm.. or u can just buy super90 TB.
skunk2 pro intake manifold is more shorter then the stock manifold. so ur air flow is more faster to get into ur combustion chamber and this give u power especially when high rev..we need the air to get in fast. beside shorter the construction inside the manifold is curve perfectly.u can go skunk2 website and check out the details.with a larger throttle body u have it give u a better response engine.
TS..your ori B16A injector is good enuff liao..except ur engine is B18C..then u need a bigger injector..
i am using skunk2 intake with s90 TB but my intake no bore.any kacau with that?or need to bore to 70mm?
Bump: i am using skunk2 intake with s90 TB but my intake no bore.any kacau with that?or need to bore to 70mm?
if you dont bore the intake, you will cause turbulence in the air flow...you will feel like the car jerks when you release your throttle.
when the air comes passes through the throttle and hits the wall,it cause the flow to be disturbed and this can even cause loss of power....you definitly need to get the intake bored to have the throttle work as it should...
another thing...having a larger throttle + intake..improves air volume , but reduces air velocity, if your head is not ported, the performance difference in using a larger throttle might not be that significant...because air volume has increased,but the air is not being pushed out quickly enough due to restriction in the flow...(sifus,please correct me if im wrong)
is your cams also stock?
get a Type R intake....with a type R intake and larger TB you'll make more power at high rpm,but you'll lose out abit on lower rpm ranges...with a ported head...then the power gains should be significant.
yeah,Zeroed has a point...
maybe the throttle upgrade you should pend 1st...super90 new around rm6xx..with that money alot of other things you can do.
the throttle wont benefit you much at stock stage(if your car is mostly stock).
IMO,a good time to upgrade is once your head is ported,get a type R or skunk2 intake + TB...if got budget change cams also to either Type R or aftermarket cams.
