B16A Double valve spring on both intake n exhaust
Oderf
Guys,
i heard that we can used double valve spring from B16A (intake) for the exhaust cam side instead of using a complete set of CTR/ITR valve spring. Some are using this setup with CTR/ITR cams. My question is, what are the pros and cons in doing this type of midifcation. How would it be if compare to a combination of CTR/ITR cams with CTR/ITR cams ?
"How would it be if compare to a combination of CTR/ITR cams with CTR/ITR cams ?"
This is confusing :alberteinstein:
regarding the early portion of your enquiry, yes it can be done BUT you have to stick back to your stock B16A camshafts regardless of OBD0 or OBD1 version. if you plan to do the "malaysia-boleh" with the bigger camshafts like even CTR or ITR, chances your valves might hit the piston during high-revs(especially when u have chipped ecu that does not have cuts). The risk is always there. The design of spring rates and tensions are meant for certain cam specs.
goshhh.... typo error... i mean CTR/ITR cams with CTR/ITR springs
DC2R and EK9 valve springs are the same. So no problems with their own engine camshafts.
ok thanks bro. btw, it's not only 'malaysia boleh' setup, i've read some non-malaysian based honda forums, some of then using this so called 'malaysia boleh' setup...i wonder is there anyone in this forum using this setup...care to comment ?
whoaaa...good idea la bro...but my engine vtec kecil only...no point using double spring for exhaust cam lo...
oittss... u've seen my engine la bro...u should know better la my friend...me know only realize lo....broken hearted again ..sob...sob...
hahhaha... dun be so sad... tru ur luck this saturday... still got one day to do something... hehe
we r in the same market... kekekkeke
ha..ha...motorsport spirit is on bebeh... do something ? yes of coz, my speedo meter kong n check engine light is on...vtec did not engage..tomorrow need to check what went wrong...haiyyaaa....:confused_smile:
we might have the same SGDM engine, but mine is a bit diff from urs....seriously...mine is really vtec kecil..same as B16A2....damn!
hmmm...its hard to believe...i dun wanna believe it myself.....some trusted mech..show me that the headset is from vtec kecil.....i dun wanna believe it but its true....i can show u..but pls do not heboh2 to all our friends lo.....i veli d malu one now.....sob...sob..:cry_smile:
hi dude,
i think ur vehicle speed sensor (VSS) already kong la... try change a new 1 n just DIY... i think it can cost u around rm 110 (spare part from honda thailand) n the original from japan around rm 150... actually where's location u guys always lepak2....
i was thinking the same too.... got to go find it this afternoon lo....
lepak2...hmmm...no specific place....could be anywhere from subang to KL to bangi to sri kembangan..shah alam aso got...
hattech-v said:
see it this saturday....
can....but surely not at nila3 speedway..so many people around maaaa....very d malu one...:embaressed_smile:
ha..ha...can ask them to gimme handicap ka..i start 10meters ahead lo...he..he..
Z
2 3
Replies
44
Views
5K
