Apexi Afc Neo with ori stand
Mr.Chaser
Johor
~Sold~
Features:
•- Compact "Piggy-Back" Fuel Management Computer (+50% ~ -50%).
•- Unit incorporates both the SAFC and the VAFC.
•- NEW "Easy" (8-Point) & "Pro" (16 Point) Modes.
•- NEW Color FED Display & Interchangeable Button and Background Colors.
•- Inverting "anti-glare" screen allowing view from both angles.
Monitor Mode: - RPM, Throttle, Battery Voltage, Correction %, Air Flow %, Pressure (Kpa), Karmann, VTEC
Setting Mode: Air Map, Air Map Graph, Throttle Point, Deceleration Air, VTEC Control, VTEC Unmatch
Etc. Mode: MOdel Select, Mode Select, Sensor Select, Analog Select, Warning Set, Display Set, Sensor Check
other:
http://www.zerotohundred.com/newforums/engine-and-performance/397058-4-1-extractor-4afe-7afe.html
http://www.zerotohundred.com/newfor...da-rx-8-4at-meter-cluster.html#post1063867195
