[After12] GENUINE Denso Racing Spark Plug
MAX_TorQue
7,000 RPM
Welcome to AfterTwelve E-Garage!!!
We do shipping internationally / COD / Credit card accepted.
We provide installation and painting as well.
Some item's price quoted below including installation or painting.Please take note.
Any kit that you are interested but not listed here, please contact us.
For order/enquiry, please contact JACK 012.312.7113.
Pls click to Visit After Twelve E-Garage
WHY buy from us:
-Authorized dealer for Denso Spark plug.
-100% GENUINE product from Denso. Money back guaranty.
-Free installation and consultation.
-Dealers / workshop / car club welcome.
DENSO Iridium Racing Spark Plug
Using 0.4 mm dia. iridium center electrode, IRIDIUM RACING displays superb ignitability and low required voltage, drawing out better performance from your car - increased acceleration, accelerator response, operational stability, and lower fuel consumption. On the circuit, the sharp acceleration and rapid accelerator response will help you win, while on city streets, it will realize a comfortable and long drive in addition to low fuel consumption.
WHY CHOOSE DENSO Racing Spark Plug:
Improved Acceleration
Unbeatable acceleration performance on the circuit.
With 0.4 mm diameter center electrode, IRIDIUM RACING plugs are the realization of superb ignition performance and spark voltage at unparalleled levels. Misfires have been controlled and will allow you to have steadily high levels of response and increased acceleration.
Improved Horse Power
More power with an ideal combustion cycle.
Through superb ignition performance and spark voltage, non-firing and misfires under a variety of conditions has been greatly reduced. As a result, combustion conditions have improved dramatically, increasing engine output.
DENSO Racing Spark Plug Features:
Specification Includes Terminal
Included with the plug comes with a terminal nut compatible to the Nology Hot Wire and most plug cords around the world. Please remove for vehicle types that do not require terminals. ( Some plugs have solid terminal. Please refer to the list. )
Built-in, Highly Reliable Resister
All IRIDIUM RACING plugs specify a resistor, and contain a highly reliable monolithic-type resistor that blocks noise that may affect electronic devices. (IW06 has no resistor.)
Highly Corrosion Resistant, Burnished Nickel Plating
Burnished nickel plating on the housing, a high level of corrosion resistance has been realized. Also, because the amount on the threads is low, the damage to the female thread in the cylinder is reduced.
Insulators for Racing
By using a new, strengthened insulator which was developed during numerous and repeated testing during racing trials, strength is improved by 20%.
All-Platinum Ground Electrode
Compared to the nickel alloy used in conventional spark plugs, the high melting point of platinum will reduce such problems as ground electrode melting and wear. Also, the 0.8mm platinum alloy is welded on and gapped without any bending, reducing residual stress and increasing durability.
0.4 mm Diameter. Iridium Center Electrode
The center electrode tip is able to be made fine using a new iridium alloy with a high melting point. The required voltage is reduced, and ignitability is improved greatly. This new iridium alloy's material composition, manufacturing method * 1, and welding method * 2 have been patented.
* 1 The addition of rhodium to improve high temperature oxidation resistance:
Japan Patent 2877035, UK Patent 2302367, People's Republic of China Patent 961022841, Republic of Korea Patent 0292083, U.S.A. Patent 6094000/6262522
* 2 Using a melting method instead of the conventional sintering method.
Japan Patent 3000955, U.S.A. Patent 5977695
Spark Cleaning Pocket
Between the center electrode and the insulator, a small pocket has been opened around the tip clearance. When there is carbon fouling or deposition, this part will discharge and burn off the carbon, restoring electrical resistance. This technology is patented by DENSO (Japan Patent No. 2727558)
Silicone Oil Coating
During the start of the race, non-starting from carbon fouling and carbon deposits can be fatal. To stop this, the insulator has been coated with a silicone coating. Using the water repellency of silicone, the insulator surface is isolated from moisture and carbon, preventing a decrease in resistance.
Housing End Face Chamfer
To improve the tolerance to abnormal combustion conditions, the housing end face chamfer has been enlarged. Be covered for slight inaccuracies in tuning. Also, because the exhaust of residual gas and the flow of new gas have been facilitated, its self-cleaning performance has been improved, making this a carbon fouling resistant design.
360° Laser Welding
The process used to join the iridium tip is a highly reliable "All-around Laser Welding * 1" process that is able to withstand various kinds of driving conditions.
Pls contact JACK 012.312.7113. for FREE Consultation and Pricing.
Others:
DENSO Iridium POWER - HERE
DENSO Iridium Tough - HERE
Please visit our showroom for more discount!!!
GENUINE Denso Racing Spark Plug available @ After12 Motorsports!
*Give us a call or visit our showroom for more discount!!!*
:: Address ::
Lot 12, Jalan PJS 11/3, Bandar Sunway, Petaling Jaya, Malaysia, 46150
:: Contact Us ::
After Yong --> 012.312.7113
:: Find Us Here ::
After Twelve Motorsports | Facebook
:: Address ::
:: Contact Us ::
:: Find Us Here ::
:: Address ::
:: Contact Us ::
:: Find Us Here ::
