Dear friends,
The petrol price has rise again . Anybobody ever tested using acetone as a kind of fuel saver . Here an article about it . It quote :
Significantly Improved Mileage:
This article about acetone (CH3COCH3) probably draws conclusions that Big Oil and the American Car Manufacturers and others do NOT want you to know. They suffer from unlimited corporate GREED. They want bad mileage. The worse, the better as far as they are concerned. Acetone is a vaporization additive rather than a fuel additive per se. It is successful in very tiny amounts from about one part per 5000 to one part per 500. Mileage seems to taper off while HC emissions actually are greatly reduced with too much acetone. The peak gain in mileage comes between .03 of one-percent and .20 of one-percent acetone, depending on the actual vehicle which may be running gasoline or diesel. Note .781 cc per liter or .78 parts per 1000 or one part per 1280 are the same as one ounce per 10 gallons. Acetone operates on the unburned portion of the fuel to gain added vaporization and improved combustion efficiency. Acetone further operates like an electron absorber. There are no bad effects whatsoever and every good reason to use acetone in your fuel. The fuel characteristics during combustion remain those of the original fuel. It just burns more completely with insignificant amounts of acetone.
Details can be read at :
http://pesn.com/2005/03/17/6900069_Acetone/
By the way where in Malaysia could be buy this acetone ?
