4G91 stuff
gilercefirorb20
1 - Air Flow Sensor + Standard Air Filter rm200
http://www.myviper.net/asviper/Air%20flow%20sensor%20%20with%20box%20kecik.jpg
2 - Distributer rm150
http://www.myviper.net/asviper/Distributor%204g91%20kecik.jpg
3 - Wiring rm300
http://www.myviper.net/asviper/Wiring%20Enjin%204g91%20without%20injector%20rail%20kecik.jpg
4 - ECU 5660 rm300
http://www.myviper.net/asviper/ECU%204g91%205660%20kecik.jpg
5 - Trottle Body rm200
http://www.myviper.net/asviper/TB%204g91%20kecik.jpg
6 - Injector 210cc + Fuel Rail + Fuel Reg rm100
http://www.myviper.net/asviper/injector%20210cc%204g91%20kecik.jpghttp://www.myviper.net/asviper/Fuel%20regulator%20std%20GSR%20kecik.jpg
7 - Power TR unit rm150
8 - Pump Power Stering rm80
http://www.myviper.net/asviper/Pump%20Power%20Stereng%204g9X%20kecik.jpg
9 - Injector 240cc + Fuel Rail + Fuel Reg rm150
10 - Inlet maniful 4G93 rm200
11 - Extractor Standard 4G93 + 02 sensor rm100
http://www.myviper.net/asviper/Hcut%204g93%20set%20kecik.jpg
12 - 4 pcs HKS S40i High Performance Plag second rm120
http://www.myviper.net/asviper/Plug%20HKS%20S40i%20kecik.jpg
13 - 4 pcs piston B8T + ring + rod taken out from engine sold
http://www.myviper.net/asviper/Piston%20b8t01%20kecik.jpg
call 0134880400location kulim, kedah & penang
bro,ur kit can install 4g91 carburator engine ah?
pm me ur best price bro....and list down what item i need to install for complete my engine make efi system....
1 - Wiring
2 - ECU
3 - Inlet maniful
4 - Injector + fuel rail + fuel reg + Petrol pump (internel or xternel ) + hos
5 - Trotle body
6 - Air flow Sensor + air filter
7 - Power TR unit (coil)
8 - Distributer
my ECU 5660 is auto, better than ECU manual because RPM cut lambat .....
hee.....canot la bro....it's very very very cheep la.....try u ask for h/cut price....
4 pcs piston B8T + ring + rod taken out from engine rm500
hmmm u installed this to ur 4G91 b4 this?
wats the size of this piston?
need to rebore the 4G91 block rite?
conrods all plug and play?
no lah .... i'm use for my gsr before ...... it's good for gsr oversize rebore ... u can get up to 2000 cc lorr .... hee ...... 82.5mm .... my block was crack because overhead ..... just use the piston .... conroads all use from gsr .....
for 4g91 oversize ...... just use piston 4g93 NA ......
BUUUMMMP for one time ........ all part still available .......
BUMP ....... full set to convert injection 4G91 RM1300.... 1)Wiring +2)ECU + 3)Inlet maniful 4)Injector 210cc + fuel rail + fuel reg 5)Trotle body 6)Air flow Sensor + air filter 7)Power TR unit (coil) 8)Distributer
great stuffs at an affordable price..dun la ask giler murah price frm this guy..all the stuffs is very affordable..go and ask h/cut shop and u ll be jumping if u compare the price..BUMP FOR U one time..he heh
tq broo ....... all items still avilable ....... xcept item marked sold ......
BUMP one more time .....
