4A-FE O2 sensor
mikrozid
Hi to all. I owned a 92' AE101 automatic with 4A-FE engine and i unable to find any O2 sensor all the way from exhaust manifold to the tail pipe. Is there any of the 4A-FE without a O2 sensor?
I think 4afe for seg 92 dont have any o2 sensor on the exhaust from extractor to tailpipe. At least mine didnt have it when it was stock and there wasnt any bracket for it
REALLY A WHAT ABOUT YEAR 1997 AE111? is there any o2 sensor?
I was really surprise that i can't find any O2 sensor for my engine. Does it meant that this model dont need a O2 sensor to run? I thought that all EFI engine must have a O2 sensor? Is the ECU the same with those with the O2 sensor? Anyone out there know if there is a model of the 4A-FE without O2 sensor? Pls advice. Thanks
not to sure about it...
but if 4A-FE (MAP) ECU...sure got O2 sensor map on it...
sure got one...cuz most car since 1980's are pre-equip with O2 sensor...!
92-95 4AFE come w/o o2 sensor.......96 & above model only comes w/ o2 sensor..
Bump: 92-95 4AFE come w/o o2 sensor.......96 & above model only comes w/ o2 sensor..
1996 onwards model is it still name as AE101? Could it be the previously took it out and bypass etc? I had already bought the o2 sensor but now looks like its a waste now.Any one want to buy? Its brand new.
Btw, pls advice how to adjust the idling speed.
Also my fuel comsumption is very high. Per litre only 7km. Is there anything i can do?
Thanks
1996 onwards is AE111. BTW AE101 in Malaysia dont even have cat converter if you want to compare. Idling can be adjust at most shop. If not mistaken idling should be around 750-800rpm
Wow...that's something new to me...
means that...the last AE101 model wasn't equip with O2 sensor...only new model AE111 equip with it ...
Thanks
what the part number for your new O2 sensor ?
I think my AE111 also have catalytic converter...
Idle speed usually adjusts itself after a week of driving
The O2 sensor that i bought is for AE101. Part number is (89465-19575). Therefore if 96' and above is AE111, then its a bit not too right le. Is anyone out there driving 1995 AE101? Or 94, or 93? Pls advice do they have O2 sensor? Thanks
Bump:
The O2 sensor that i bought is for AE101. Part number is (89465-19575). If lets say 96 and above is AE111, then why this o2 sensor part number is for AE101? Pls help............. confused. This o2 sensor is stated in the AE101 parts books............
maybe ur sensor ae101 for 4age engine.
Bump: 4efe o2 sensor 1996 model (89465-12450). ohm meas reading 14.2ohm same 4age bt o2 sensor resistance.
huuu...why your part number is different ?
maybe interchangeable :D
here some info :
89465-19575 - yours...not sure which model use it...huuuu
89465-12280 - 4AFE
89465-19175 - 4AGE 16V (not sure small n big port interchangeable, supposely can i think)
89465-19495 or 89465-12290 (SVT)
89465-19685 - 4AGE 20V (BT)
It seems like i will not be using the O2 sensor. Anyone out there who need the replacement? Its going for sale.........
Here is the photo attached of the O2 sensor.Its brand new. Those who interested to buy, pls PM me. Thanks
