I have a set of AE101 silvertop individual throttle body (ITB) or known as 4 throttle, or some might say quad throttle. I am planning to mod it to fit in my 4g93 head(old news, now fitting in mivec).
things that i need to consider are as follows:
1) fabricate an 'adaptor' or intake manifold to fit the ITB to my head. this will include the injector 'holes' and all necessary things.
2) make a closed chamber or intake plenum so that i could fix my AFM (air flow meter) which will go to the left side, compared to the toyota's original right side.
3) some sort of piggyback is required, luckily i already owned an SAFCII. to compensate for the massive air that is coming in, hence the fueling must be correct.
also i'll need an adjustable fuel regulator.
so,.. im asking for u experts out there.. am i in the right track? just want to get it running 1st,.. if i have more $$$, i'll probably get a standalone and MAP sensors so that it could be an open throttle, and not in closed chamber.. probably tuning would be easier then.. anyhow.. what do ya think of this?
