204WHP 4A-GE 16V Redtop
EFN
Batu Caves
Taken from www.club4ag.com
ENGINE:
1992 Toyota Corolla GTi-16 4A-GE 1600cc non T-VIS - Fully rebuilt with 0.5mm o/s pistons and ACL bearings
Balanced crank and flywheel
Lightened flywheel to 5.4kgs
Fully ported cylinder head
Competition valve springs
11.0-1 compression ratio
41mm individual throttle bodies with 39mm inserts
WebCon throttle position sensor
TRD BD3 camshafts
Adjustable cam pulleys
Magnecor Plug leads
MR2 SW20 fuel pump
FSE adjustable fuel pressure regulator
EXHAUST:
Standard manifold & downpipe
Powerflow exhaust from downpipe back
ENGINE MANAGEMENT:
Toyota 4A-GE ECU modified for 9,200Rpm rev limit
GReddy eManage piggy-back ignition & fuel ECU
wow.. don't even have to rev to 10k rpm to get that kind of power? impresive...
204whp... that whould be almost formula atlantic power at the flywheel lor.. :ph34r:
but then where is the powerband? no point also if only make power from 7-9k :lol:
is it still streetable? like sunday driving under 3k rpm?
