Did you contact Steven?
Yes i did, we chat alot, he stopped doing the traction control thingy, but now i am discussing with him how to get the "SMG" work again on the beemer.
Thanks,
Ken
Does it use pillowball top mount or original rubber ? Also what is the price and spring rates?
hmphh, was hoping to use rubber. not into all this "racing" stuff.Just their aluminum top mount, i got special prices, i think you should contact them directly. Spring rate is 12kg front, 9kg rear.
Thanks,
Ken
I thought that only happens with mcpherson strut ? If double wishbone no problem right ?I learnt from my previous lesson, stock mounting will not go well with the adjustable spring, it will constantly bind itself when turning steering wheel which annoys the f out of me.
Thanks,
Ken
Sounds like your alternator alone take a lot to run it.....Dear All,
For those who interested with the low voltage issue i had with my converted E46, problem seems to be solved 80% after installed the smaller alternator pulley. At low idle with full accessories on, fan kicked in, the voltage is 13.2-13.4v. Previously encountered the RPM shut off issue was also solved after the change of pulleys. Furthermore, felt like the car is accelerating much faster too, gear kicked down also much more responsive and gear shifting is smoother, especially at WOT, previously felt a little lag but i don't think alternator charge has anything to do with it. Oddly, i got better gas mileage which is another plus.
Just found out we did not add another ground cable from alternator to the battery, if i did that, i think that will stabilize the voltage even more.
Will keep you guys posted
Sounds like your alternator alone take a lot to run it.....![]()
Funny thing is with smaller pulley, you getting faster acceleration and better mileage, which actually should be the opposite......lol
The electrical systems received enough juice and operating at optimum level.Funny thing is with smaller pulley, you getting faster acceleration and better mileage, which actually should be the opposite......lol
Maybe spinning at the wrong speed, therefore producing lessThings are strange somehow, all i can say is i had very good luck on my 1st attempt in this type of project, seen many people try to do the same and ran into lots of problems. It would be the original pulley has some sort of worn on it but it not visible. We tried to swap in 120 amp alternator from Lexus LS300, just need to swap the pulley before putting on, funny thing is, the voltage produced is even worse than original alternator. Hence push us to modifying smaller pulley on original alternator and voila ... solved most of the issues.
Thanks,
Ken
Yah! probably with added voltage/current all running fine nowThe electrical systems received enough juice and operating at optimum level.
Its like a bulb, with small current it will produce light. It gets brighter when we increase current input.
Ever notice your car felt like new after a battery change? If old car, u wont feel any difference, on car laden with electronic it felt like a too overhaul.
Why not mod the e46's original alternator in?
Hey Ken, didn't you consider the 2JZ alternator? It's almost PNP and higher output
. We have tried with LS300 and Aristo 2JZ alternator and they didn't work better than my current one before i swapped in a smaller pulley.Cant a bracket be made?Erm ... not sure can we do that, bmw alternator mount points aren’t the same.
Probably too much work, changing the pulley was much easier......lolCant a bracket be made?
:driver...
