I recently installed a 21row cooler on my Perdana V6, bought it for RM320 Hayden. Had some problems finding transmission oil hose so I used Unigawa's fuel hose that was rated to 150psi (I know I shouldn't). At least the pressure rating seemed acceptable. I am now worried about the temperature rating of the hose. The Unigawa website says it's only rated to 70 deg C. Anyway, it's still running fine now, but can you tell me where I can find transmission oil hoses for sale?
---------- Post added at 08:06 AM ---------- 6 hour anti-bump limit - Previous post was at 07:59 AM ----------
Errrmmm, you need to be careful. Engine oil coolers are not normally the same as transmission oil coolers. At least they shouldn't be. Engine oil pumps are gear type pumps which are what they call positive displacement (i.e. high pressure). Transmission is a centrifugal pump (lower pressure). You would normally see engine oil coolers being the fin-tube of frame type, not like the radiator style of the transmission oil cooler.
You should be able to get those higher rated hoses from spare parts shops.
And thanks for the info on the coolers! I didn't know that. Good thing to share and thanks for sharing!~
. It's the whole car going for RM29k nego!
