my 7age 20v rev till 9000rpm with power band at 8600rpm
using toda 288 cam.used v power fuel
With VVt? ECU??
Maybe you guys should have form a dyno registry.
ae86 timing belt
for BT 20V needs 115 toothed = 16V belting, for 16v head needs 117 toothed = porch924/renault..maybe the cam pulley location are narrower, or due to tensioner location..IMHO..correct me if I am wrong
Great info..
How bout d exractor? U guys custom-made?
just an info...
the only reason i didn't choose this route is the flywheel bolts which has only 6 bolts...
some sites i've mentioned in other post shows the flywheel 'give way' and cut off everything...
luckily it's in a FR, otherwise people might get killed...![]()
just an info...
update..my knock sensor problem repaired and solved..now no more check engine..the idle really smooth..ran as good as before..![]()
yes meg..there are better option..say..1.8L 2zzge more powderful! :top: but u dont need 1.8L if u are having that rev limit..already powerful bro :)
). Please note that this...
